Attractor wave, Lunchbox in Revit 2021.1, how?
i want to run a older script, is there a different package for attractor wave.
Can i do an workaround?
KR
Andreas
2021-12-15_15h56_25
Assuming your issue is that the node was deprecated and doesn’t exist in your current version… you need to install an old version of the package that contains the node. You can always copy the dyf to a different location to maintain it separately from the core package.
Big step forward!
but still not working! for any reason it does not work with points!?
it remains with cero points… … i played with lacing but it still not works
KR
Andreas
Workaround
