Just had a look at your latest graph - you’re close!
Notice that you are feeding a surface into the Surface.ByPatch node that you’re inputting into the Topography.IntersectionWithPlane node. No need for the Surface.ByPatch node as you already have a surface - you need to give the Topography.IntersectionWithPlane node a plane input This thread should help:
