Goodmorning everyone! I need to place floor site components on a linked topography. In this case the components do not recognize the host and behave like normal level-based elements. Is there a way to automatically move elements on the toposurface? I’m trying with Dynamo but with poor results … thanks to anyone who will give me an answer! !
trees_site|690x400
This is how i would approach this:
- Get the origin point from each floor site component.
- Create a line with the Z-axis (and the origin) and extrude this line 1km up and down.
- Get the intersection point from this line and the top face of the surface.
- Now you have 2 points which are the same in X and Y but different in Z. Get the difference using a very simple Z1 - Z2 formula.
- Move (translate) each object in the Z-direction according to this value. positive or negative shouldnt matter it should always end up so that the distance is now 0m.
Thanks, now I’ll try to create a script, I’ll keep you updated
Hello Daan,
Thanks alot for your input.
I struggle with step 3.
3. Get the intersection point from this line and the top face of the surface.
Any tips on how to achieve that?
Hi @gerbenKAG9F,
To get the intersection point between, in this case a single surface and multiple lines, you need the node Geometry.Intersect (see Dynamo Dictionary). This will output a list of points where your lines intersect with your surface.
Now you can use these points to measure the distance from your starting points.
