Associate family parameter in a family
Ok I got it sorted ! It needed an Autodesk.Revit.DB.Parameter for the element parameter and Autodesk.Revit.DB.FamilyParameter for the family parameter. The below is a bit messy and can use some improvement but it worked for my purposes. It will only process one element but it will associate multiple parameters; give the Python script node a list of parameter names (strings) and the family parameter names to associate them with like so:
Script:
elem = UnwrapElement(IN[0])
paramNames = IN[1]
famNames = IN[2]
if not isinstance(paramNames, list):
	paramNames = [paramNames]
if not isinstance(famNames, list):
	famNames = [famNames]
elemParams = elem.Parameters
famParams = doc.FamilyManager.Parameters
elemAssoc = []
famAssoc = []
for param in elemParams:
	for name in paramNames:
		if param.Definition.Name == name:
			elemAssoc.append(param)
for fparam in famParams:
	for fname in famNames:
		if fparam.Definition.Name == fname:
			famAssoc.append(fparam)
for i,j in zip(elemAssoc, famAssoc):
	doc.FamilyManager.AssociateElementParameterToFamilyParameter(i, j)
OUT = elem
Let me know if this works for you as well & if you improve upon it please share :slight_smile:
