Associate family parameter to connector element
So i have to assign a parameter i created in a family to a connector element autommatically through dynamo, is there a way to do that?
Thank you!
I tryed doing this, but it didnt work. I’ll post de dyn file with the family fileAtribuir Diametros aos conectores.dyn (14.0 KB)
Caixa de Passagem 4x4.rfa (536 KB)
Well, i don’t know anything about python script. But i couldn’t make it work for a list of elements, but i tried to do it for each element in a list… creating a lot of nodes for doing so, and it worked.
Hi @ramoon.bandeira ,
I had a look at your script
  •   I deleted the ā€œcreate parameter partā€, since the parameters are already there.
  •   I got no errors
  •   The 4 connector elements (not being 20) are assigned properly.
No need to create additional nodes in my opinion! See attached.
The dynamo code does not return any errors, but if you go to the family after the script execution, you will see that that all 4 connectors are associated with parameter C1. When it should be:
Connector 1 associated to C1;
Connector 2 associated to C2;
Connector 3 associated to C3;
Connector 4 associated to C4;
Thats why i have to repeat it for everysingle parameter association.
by the way, the script in that python node is the following:
clr.AddReference(ā€˜RevitAPI’)
clr.AddReference(ā€˜RevitNodes’)
clr.AddReference(ā€˜RevitServices’)
elements = IN[0]
epSearch = IN[1]
fpSearch = IN[2]
if not isinstance(elements, list):
elements = [elements]
if not isinstance(epSearch, list):
epSearch = [epSearch]
if not isinstance(fpSearch, list):
fpSearch = [fpSearch]
for e in elements:
e = UnwrapElement(e)
elemParams = e.Parameters
epNames = []
fpNames = []
elemAssoc = []
famAssoc = []
for ep in elemParams:
	epNames.append(ep.Definition.Name)
epDict = dict(zip(epNames,elemParams))
elemAssoc = [epDict.get(ep, "none") for ep in epSearch]
famParams = doc.FamilyManager.Parameters
for fp in famParams:
	fpNames.append(fp.Definition.Name)
fpDict = dict(zip(fpNames,famParams))
famAssoc = [fpDict.get(fp,"none") for fp in fpSearch]
for i,j in zip(elemAssoc,famAssoc):
	try:
		doc.FamilyManager.AssociateElementParameterToFamilyParameter(i, j)
		error_report = "No errors"
	except:
		error_report = "can't assign parameter"
OUT = elements,error_report
You are assigning to element instance ā€œConnectorElementā€ with instance familyparameter ā€˜Diameter’ the Familyparameter c1, c2, c3, c4.
So it will grab the first item in famParameterNames list … and then stops.
Changing elemParameterNames to { Diameter, Diameter, Diameter, Diameter } will result in 4 times c4 assigned.
The way it works is if you have c1, c2, c3, c4 parameters available in your elementinstances (connector element) … so assining c1 of your family will trigger the element instance c1 too. etc. (unsure if you can assign / alter a connector element though)
Or do I misunderstand your question?
Or if connector 1 associated to C1 … what is connector 1? it’s not defined?? Or is a random connector assigned to c1??
lets summarize the code:
after filtering the connectors, what remains are these four connectors, i created 4 instances parameters and i will associate Family parameter C1 to conduit connector (wich i labeled C1 in the picture) Diameter Parameter, then i will associate Family parameter C2 to conduit connector (wich i labeled C2 in the picture) Diameter Parameter… and so on
That’s what i’m trying to do.
@ramoon.bandeira,
you could add fpSearch.pop(0) after you did your first assignment.
clr.AddReference('RevitAPI')
elements = IN[0]
epSearch = IN[1]
fpSearch = IN[2]
for e in elements:
	epNames = []
	fpNames = []
	elemAssoc = []
	famAssoc = []
		try:
			fpSearch.pop(0)
		except:
So it assigns, removes first item, assigns, removes first item etc.etc. Now 4 connectors have individual c1,c2,c3,c4 assigned. The order of this isn’t set obvious.
Does this help you?
That’s it!
Solved my problem!
Thank you!!!
