Hello!
I’m starting to learn Dynamo, and I’ve faced mysefl struggling to set the value for a Key Schedule.
I got the Key Schedule parameter “BitolaPressão”, and I want to use Dynamo to write this value in some duct sections, based on a list.
The problem is that the first value of the list is being repeated for all the Names of the schedule, and I want to match the value “line by line” from my input list. Must be a list structure problem, but I didn’t find info on writing info on the “Key-name” parameter inside a Key Schedule parameter.
@EGJ_INTT ,
i do not have straigt forwart solution but here some snippets to get closer
#📦 Variables
p_key_name = 'Room Style' # Write Your Key-Param Name!
key_schedule = None
#1️⃣ Get all Schedules
all_schedules = FilteredElementCollector(doc)\
.OfCategory(BuiltInCategory.OST_Schedules)\
.ToElements()
#2️⃣ Get Key-Schedule
for schedule in all_schedules:
try:
if schedule.KeyScheduleParameterName == p_key_name:
key_schedule = schedule
break
except:
pass
#💡 Ensure you found matching schedule
if not key_schedule:
forms.alert("Can't find matching Schedule.\nPlease Try Again.",
exitscript=True)
#3️⃣ Get Possible Key-Parameter Values
key_values = FilteredElementCollector(doc, key_schedule.Id).ToElements()
dict_key_values = {key.Name : key.Id for key in key_values}
#OUT =
you have to adapt it to your project… this stuffs runs currently in PyRevit
t = Transaction(doc,'Change KeyParam')
t.Start() # 🔓
random_id = dict_key_values.values()[0]
p_key = room.LookupParameter(p_key_name )
p_key.Set(random_id)
t.Commit() # 🔒
KR
Andreas
