I have a list of lists with a variable number of items in each sublists. I want to create a list with letters A,B,C,D… to assign to each item in each list, resetting when going to a new list.
Something like this:
Can you help me?
Can you help me?
First issue you’ll face is that you cannot rename a family by instance… But you could make a parameter holding the letter, or if it is to be used inside dynamo you could make the family into strings first and then use a combination of the count node and list levels, but do show your attempt first
My first attempt is using the list.cycle node, but I end up with the same letter assigned to each item in the sublist.
I guess i’m missing some logical step here…
PS: Sorry about the messy dynamo, I’m still testing…
It looks like you’re really close actually. Would this work for you?
That’s perfect! Thanks
