HI All, I would just like to know it is possible to Get the type name of an element; say a door or pipe, create a worksets based on that TypeName and assign that to the element as well.
I am able to create the workset name based on the type name but i cannot assign it to the element.
Hello @Revit_Noob …try something probably could work
Actually that is what I am doing but I am getting null values in the Workset.ID
EDIT :
It worked. I replaced the Workset.Id node from Zhukoven.Revit package with the OOTB.
I didn’t realized am using the wrong node.
Thanks @sovitek
I am trying the same method with System Pipes, am getting an error in the SetParameterValue .ByName
The Parameter is Read-Only
Nevermind… I managed to get it worked
