Assign Material to all Object Styles
Hi - I’m attempting to change all object styles (GraphicsStyle) in a project to have the same material. This is part of a graph that overrides consultant models to be of one solid colour.
I can collect all Graphics Styles using Python but I can’t find how to set their material parameter. Can this be done?
gstyles = FilteredElementCollector(doc).OfClass(GraphicsStyle).ToElements() mat = UnwrapElement(IN[1])
Thank you.
Did you find a solution for this? I’m trying to do the same thing with Dynamo.
Love to know either way!
Thank!
No solution sorry. Needs someone smarter than me! :slightly_smiling_face:
You do not set it on an Object Style object, you set it on a category. These objects just read that property.
I had a problem where i needed to remove all materials from object style (for IFC export to work correctly) and this is the code snippet.
cats=list(doc.Settings.Categories)
exit=[]
for i in cats:
	catType=i.CategoryType
	isModelCat=catType== CategoryType.Model
	if isModelCat:
		if i.Material != None:
			i.Material=None
			exit.append(i)
also see this post
