I’ve been looking for a way to change the line colors of annotation objects in object styles with a dynamo script but i can’t find anything.
I don’t mean overriding by view.
Is this even possible?
Any thoughts or feed back is greatly appreciated.
Kind regards,
Hi @dNWQ7M,
For the object styles settings, use the Set SubCategory Properties node.
You can also set the line pattern and the line projection weight if necessary.
Hi @Alban_de_Chasteigner ,
This is exactly what I was looking for, thank you.
hi @Alban_de_Chasteigner
I’m getting null values in the Category of Set Sub Category…
