Assembly Instance - element does not support assignment of user-specified name
Hello forum
I am having an issue with the renaming of one or two assembly instances. Most of the assembly instances I rename through Dynamo work fine, but I am having one or two which do not work and I get the warning below:
I can manually rename the assembly instance in the project, and I have tested Dynamo on both workshared models and detached model and it still does not work.
Can anyone offer some ideas on what the warning could mean? Thank you very much for any help.
Cheers
Tim
Hi @TimGreatrex steamnode-synthezise toolkit written in python have one and probably other as well
and with setname
Hi Sovitek
Thank you very much for your answer, this worked!
I used to use this node previously, but I started using the SetName as I thought it would not make a difference. So it works better using Python code?
Thank you very much again!
Tim
