Area Tag's Tagged element can't be found
I am struggling to get tagged Areas from list of Area tags.
I first tried Tag.TaggedElement, but the node is reporting Area tags are under Revit.Elements.UnknownElement object type.
So I took an attempt to replicate code from link below but it is still telling me the same thing.
http://dynamobim.com/forums/topic/get-tag-host-element/
Does anyone know a way to capture Area hosts from Area tags?
I appreciate your help in advance!
Hi @JTY
This should get what you are after:
#Import the Revit API
clr.AddReference('RevitAPI')
#Import DocumentManager and TransactionManager
#Reference the active Document and application
#Start scripting here:
tags = IN[0]
OUT = [i.Area for i in UnwrapElement(tags)]
This is Revit 2018.2 and Dynamo 2.0.1 BTW.
That was fast @MartinSpence !
This solved my problem, Many Thanks to you! I should probably start studying Revit API…
No problem :-).
A little bit of python and learning to navigate the API is rewarding! It does also require investment though :slight_smile:
How can make this work for dynamo 1.3.3?
Hi Francisco,
You can also use the Tag Get tagged Element node that works with areas, rooms, spaces and other elements.
Tag%20Get%20tagged%20Element
Thanks Alban!!!
is this a new node on your package???
You’re welcome.
You probably need to update the package if you can’t find it.
I am using dynamo 1.3.3 is your most up to date package compatible?
Absolutely.
All nodes are developed in 1.3.3 to ensure compatibility with version 1.3.3 and 2.0.
However, the latest versions of the package are released to the Package Manager with Dynamo 2.0 to try to minimize failures on some computers when updating or installing the package on version 2.0 (a strange bug).
great,
Many thanks!!!
Another option posted to your original request.
