I’ve been trying to make an area attractor point that only takes in the distance of a certain area near the attractor point and leaves anything beyond say X distance away from it alone and uneffected. I’m still a novice so my question really is whether or not this is possible through Dynamo nodes or is this something that should be done through some scripting in python etc?
I took the sample file and have been trying to modify it to work so the file may be a bit messy. Thanks in advance.
Core_AttractorPoint
Hi David, check out this file. Note that the forumulas for the Formula node are documented at http://ncalc.codeplex.com/.
The change is to add a condition to the height of the cyliders:
Instead of using a formule for maximum height is it possible to add a surface (such as a topography) as an input for the heights of the cilinder?
This formula was very helpful. Thanks for sharing. I applied it to a perforation attractor to prevent any overlapping circles in the perforation pattern by capping the diameter.
