Any idea why Dynamo is not returning the value in this case?
I'm trying to select areas based on their scheme
Area Scheme Id ( not ID )
Ahahahahah too early for me, right on for you. Thanks for catching that
Hi
can we get “area scheme” name as a list
thanks
Hi vikram,
I want to calculate Volume of those area, I know revit can not give direct volume of the area plan, so need to apply formula "Area x height (height of level ), Area I get as out put of parameter, but how can I get height of level.
actually how can I retrieve height of corresponding level which belongs to are as all the level height are not same.
also attaching my code block please have a look and guide if I can do something better then this.
Â
thanks
I’m unable to decipher anything from the images you’ve attached, but I am quite certain you aren’t doing the right things.
A suggestion: Instead of working with Areas, why don’t to try to extract the required information from Rooms or Spaces.
Â
Hi Vikram,
thanks for answer.
Actually I am working for dutch company.
Rooms and spaces we are using for net area.
and “Areaplan” for different requirement. like.
Gross Area. which contain exterior boundary of building.
GBO = Gross area - (shaft+elevator+stair+common bearing structure)
BVO = there are 3 kind of calculation in this area.
a) Fully covered area.
b) Semi covered area (like covered balcony or loggia)
c) open area (like open terrace, balcony, or loggia)
Â
so all my area are included with bearing and non bearing wall. due to that I need area plan. as i can not create multi pal room in same level on top of each other
Added my dynamo files so you can check.
.NEN_2580_room_function NEN_2580_room_export_import
Â
Hey Jason, try to set the “Curve.ExtrudeAsSolid” to longest,
edit: sorry did not see the “null” values,
no idea what is wrong
