Archilab Bumblebee functionality for Revit 2025
Link didn’t post, but I think I know what you’re referring to.
The tabs vs spaces thing is fairly quick to fix in copilot with the right command - personally I prefer using it live in the IDE though. For what it’s worth spaces is the standard which Dynamo uses (I lost that battle), so if you’re writing the script for use in a Python node in Dynamo then ChatGPT is actually wrong, though I’d argue it’s Dynamo which is off. :upside_down_face:
Either way, the pace of evolution is fast across the board so we have to evolve our mindset to keep up - all of which is more hours on us which most won’t be accounted for and certainly won’t be planned on… :skull:
Made a few amendments to my workflow to use CSV instead of XLS export.
it now looks for a folder path and creates it if it doesn’t exist, names the files based on the required table names in Excel and spits the files out with a date on the end.
New macro in Excel to scan the folder for the latest files an pull that data into the required tables, deleting existing data first, this bit is surprisingly quick.
All in not a bad workflow, and it gives me a history of all the exported data should I want it…
Oh man this is a big benefit I didn’t even think of… putting it in my back pocket for later!
