archilab_Bumblebee - 2023 and higher update?
Hi, more of a request than question - and mainly to the honcho @Konrad_K_Sobon :slight_smile:
Will there be an update to Bumblebee package for Dynamo for Revit 2023 and up? Sadly Bumblebee nodes - specifically Write to Excel BB Data nodes don’t work anymore.
That’s too bad since these were very good for handling bigger Excel exports as OOTB Data.ExportToExcel node is quite chunky and it’s impossible to export an data-less column (or to put a break in the data) with it.
Hi @filip.kabelis guess you have some other issue then, should work both in 23 and 24
It works :slight_smile: I’ve been trying to make OOTB node for 2 days now with reinstalling M$ Office, installing older Excel versions, because I thought that if BB Data node shows IronPython Object it means it’s obsolete. Thanks for making me try it once more
Where can i get this package bumblebee? I am trying to search it through serach packages through dynamo but its not showing up. Revit 2023.
