Archi-Lab Nodes
Hi all,
Every time i save the script and open it again it showing the below issue that extra output branch is adding to the node any ideas ? @Konrad_K_Sobon
Thank you
If you’re using Dynamo 2.x, this likely indicates that you’re using an old version of the Archilab package. Update and see if that resolves things for you.
Solved, Thank you
