Hi all,
I’m experiencing a problem when using the View.ApplyTemplate node. I can’t see where I’m going wrong.
As far as I’m aware, the data type is correct and there are no errors showing. The problem is it’s just not applying the template.
Any suggestions?
Kulkul
2
Hi @James_Washbourne
Could you show the values of View.ApplyViewTemplate?
Kulkul,
I’ve put a watch node on the end and it just says “Null”
Strangly, if I change the lacing to longest it applies some templates but not in the right order.
Regards
Kulkul,
Sorry I think the lacing has sorted it, Revit must have been playing up. I’ve just shut it down and it’s working fine now.
