Hi there,
I Imported a surface from revit and i am trying to make a running brick wall.
I managed to get the points in the location i need, but the when i translate points and place cuboids they do not align with the surface.
Can someone help?
Wall Grid with bricks.dyn (24.3 KB)
@jorge.vieira Youâll need to post the Revit file too
Sorry about that.
Revit model attached
Gen Brick wall test.rvt (1.7 MB)
@jorge.vieira This should solve your problem
Wall Grid with bricks.dyn (1.7 MB)
Thank you so much for your help Vikram.
The Cuboids aligned nicely, but the geometry translate is still not on the surface.
Is there a way to translate using the surface as a coordinate system?
Many thanks
@jorge.vieira I suppose this should be alright
Wall Grid with bricks.dyn (35.8 KB)
Hello Vikram!
I tried this on my Wall (I have a Wall that is curve both in plan anda elevation). It align perfectly with my surface. However, the geometry of bricks set doesât work.
Am I doing something wrong?
thank you
Iâm sending my file by Wetransfer
https://wetransfer.com/downloads/8e628f66b0bd42695a34790be3a0e3b220170127153436/436aab8bbd834783e46c49a994229e4220170127153436/597a58
Yna_Db
January 27, 2017, 3:44pm
9
This thread has been solved already. It would be better to continue this discussion where it began:
Hello!
I have a Wall on Revit, itâs curve both in elevation and plan. So, i would like to repeat a brick set in this Wall using Dynamo. I saw a tutorial that helped me to repeat a brick set through a line/curve in Revit. From this, I established any height and the bricks adapted to this line (using âCurve Coordinatesâ). However, I canât get a curve in elevation of the Wall, since this method only can divide equally the bricks by the Wall/curve!!!
there is a way to repeat the bricks importing mâŚ
You can reach people on the forum by using the @ tool, but itâs also important to read the forum guidelines first (if you didnât yet):
One of the main goals of the Dynamo community is to help others. One way to do that is by answering your questions. But to get the right answer, youâll first have to ask your question in the right way. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions on how to achieve that. Do not think of these suggestions as rules and especially do not take them as a guarantee of getting an anâŚ
Hello, I would like to create a brick facade which curves in plan and section. The Wall grid with bricks above was very helpful as starting point. I would like the bricks to not âwarpâ though, so that the orthogonal geometry creates a stepping texture across the warped host plane. I assume this is the appropriate thread, I can include an image to help illustrate what Iâm looking for if need be, thanks in advance for any help!
