Im note sure what im doing wrong, This has worked before. if anyone can help me id appreciate it.
SplashWall.dyn (23.7 KB)
Did you try setting the lacing to longest?
yes it still returns index 0 only
Maybe try using Alignment By Name to get the specific alignment you want (single item instead of a list) or set the levels on the alignment input port to @L2.
i restarted Dynamo and it worked with long lacing.
