Hi All,
I have and issue creating sub-lists in python. Here is my original list:
and I want to get the first and last index of every sublist, acording the indices from the original list. Here’s an image to illustrate this:
This is a part a python code. I’m not working with OOTB nodes.
Thanks in advance!
Hi Jorge,
Try to append the values in a list inside the loop. (I took this example from an old post on this forum).
Or something like this:
There’s probably a cleaner way of doing this but a simple use of append will work.
clr.AddReference('DSCoreNodes')
from DSCore import *
dataEnteringNode = IN
items = IN[0]
inlist = IN[1]
newlist = []
for indices in inlist:
sublist = []
for i in indices:
sublist.append(items[i])
newlist.append(sublist)
OUT = newlist
Thanks both @Nick_Boyts and @Giovanni_Brogiolo for the response. I’m creating list using append, but I’m looking a bit further. I can’t manage to get the algorith to do the task mentioned above.
I could get the indices from the “existe” and “no existe” elements, but I need to get the indices in the same list.
inic_tramo =[]
for i in range(len(tras_arriba)):
aux = []
for j in range(len(tras_arriba[i])):
if tras_arriba[i][j] == 'existe':
aux.append(j)
j = j+1
inic_tramo.append(aux)
fin_tramo = []
aux = []
if tras_arriba[i][j] == 'no existe':
aux.append(j)
pass
fin_tramo.append(aux)
OUT = (inic_tramo,fin_tramo)
OK, I think I understand now. So your sublist of indices will be the first “existe” and the first “no existe” the list encounters, then you begin a new sublist doing the same thing. Should be doable. I’ll play around with it.
Is your end goal to get the indices or to convert your list into sublists based on those indices?
The goal is to get the indices, so I was thinking of a sublist containing the first and the last item of every sequence “existe, existe…,no existe”.
If there is a sequence with only a “no existe”, this sublist contains only one item.Like the case of the elements 7,8 and 11 from the original list.
nailed it!
resultado = []
aux = []
resp = []
for j in range(0,len(tras_arriba[i])):
aux.append(j)
aux.append(j)
resp.append(aux)
aux = []
resultado.append(resp)
