yeps 2 and convert string to number
Only drop 2 the first time. Youāre thinking you need to drop again because your list hasnāt changed. Dropping 0 is removing nothing so the transposed list still has the headers.
Hi everyone!
Thank you all for your help so far! I have been ill and had a few other things to do but now i am back on this project and this is what I have so far
Going forward, what codes would I need to be able to place the items (they are also Revit files ) that I need using these coordinates and what we have achieved so far?
do you mean a revit family, then try family.instance.by point or similar, it will depends on what kind of family you will insert
That doesnāt seem well thought out⦠certainly a miss in the documentation or node functionā¦
Edit Ok - seems a documentation miss. Will confirm and let the team know later.
yes possibly, I just saw itā¦but havenāt gone into itā¦holiday this week
Assuming that this is a geolocation site boundary pointsā¦
Couple of things to note when developing the logic for this is to take in the following;
- project units in meter or milimetres
- the position of the internal origin / pbp / survey VS the point value indicated on the excel
- basic deductions required for the setup and to consider the rotation of the project.
