Hi everyone!
I recently needed to adjust the bottom of a large number of grids that were arrayed in a radial pattern for a circular building (Revit 2023). And I couldn’t use a scope box because the 2d extents have to be set on one floor plan and propagated to a number of other floors. The extents of the grids in plans were easy enough, but now I need to adjust the bottom of all these radial grids so that they don’t appear on our first floor plan. I know filtering is possible but I was trying to use Orchid’s Grid. Vertical Extents and Grid.SetVertical Extents nodes to adjust the bottom extent.
The problem is that no matter how hard I try the bottom extent always goes negative. If the bottom extent is 0 an I change it to 10, it will show -10. Even if I move the grid above 0, adjustments always result in negative numbers. The top extent is fine and adjustments have the expected result. The only workaround I found was moving the grids vertically and then reducing the top extent. But that can’t be the way? Right?
I made a very simple file to test this out and I am uploading the script I used.
