Set Grids Vertical Extents
I am attempting to set the vertical extents of structural grids in my current project to match the vertical extents in of the structural girds from a linked model. I am trying to utilize Data-Shapes’ node “Grid.SetVerticalExtents”. I am not entirely sure I am inputting the correct information into the node. Please see below image and attached graph. Any assistance would be appreciated.
Set Grid Extents from Link Grids.dyn (7.1 KB)
Set Grid Extents
@Mostafa_El_Ayoubi - Do you think you can provided any insight on how to use the “Grid.SetVerticalExtents” node from Data-Shapes package?
Hi @jmmiller,
here’s how to use it. It’s pretty straightforward (the node modifies all grids in the project):
Thank you @Mostafa_El_Ayoubi. That solves one issue I was having. Originally I was trying to feed in points for the inputs. Is there way to modify the node to accept a list of grids and extent inputs? I have been able to generate some python from the original node to accept a list of grids, but I am not sure how to modify the “SetVerticalExtents” portion to accept a list of values. See below for Dynamo graph and python code. Any additional help would be appreciated.
Fix Grids extents_beta.dyn (4.1 KB)
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
UIunit = Document.GetUnits(doc).GetFormatOptions(UnitType.UT_Length).DisplayUnits
def convunit(x):
	return UnitUtils.ConvertToInternalUnits(x,UIunit)
grids = []
for i in IN[2]:
	grids.append(UnwrapElement(i))
for g in grids:
	g.SetVerticalExtents(convunit(IN[0]),convunit(IN[1]))
OUT = grids
this will do it:
IN[0] = list of grids
IN[1] = list of bottom extent Z values
IN[2] = list or top extent Z values
here’s the code:
#Copyright (c) mostafa el ayoubi
#Node-mode www.data-shapes.net 2016 elayoub.mostafa@gmail.com
def convunit(x):
def tolist(input):
	if isinstance(input,list):
		return UnwrapElement(input)
		return [UnwrapElement(input)]
grids = tolist(IN[0])
for g,bottom,top in zip(grids,IN[1],IN[2]):
	g.SetVerticalExtents(convunit(bottom),convunit(top))
OUT = grids
Thank You @Mostafa_El_Ayoubi. This is perfect. I really appreciate your help.
what about horizontal extents?
which package is this? please and thank you.
Data-shapes
I’ve the same question @Mostafa_El_Ayoubi , is there any option respect to this?
