Hi, I’ve been on a mission to add the current time of a view to the end of the views name. Turning into a mission. I get the hour but its coming out as a counted number. Not the actual hour. Any suggestions?
How far I’ve gone trying to do this
Try this in a code block.
x>12?(x-12)+“PM”:x+“AM”;
It checks to see if x (input time) is greater than 12 (so 13 and up).
If x is grater than 12 then subtract 12 (14-12=2) and then add PM to the end (2PM)
If x is less than 12 then simply ad AM to the end.
You could also use string split on the overall date and input the year with a space after as the separator then get the last item from the output list.
Steven
wonderful idea. However I couldn’t get your formula to work in the code block
Did give me an idea to do this though. Its kind of mental but its fun and works I’m not sure how to extract the sun settings from a listed view. Appears you can only get it from a current view.
Maybe it’s the quotes if you did a direct copy and past?
It’s working for me. Made a quick change to deal with the 12s
Thanks man that works
