Adding shared Parametrs from text file to RFA
Unfortunately that’s not working for me…
Add Share Parameter to RFA-MKAByType.dyn (116.3 KB)
EDIT: Images don’t expand when clicked on, when did that happen?!
Ok ok…
I get a different error now :slight_smile:
Add Share Parameter to RFA-NoExcel.dyn (100.3 KB)
It’s awesome that you’ve got back to me that quick :slight_smile:
I have updated and tried to utilise the new nodes, unfortunately I am now getting a slightly different error?
I tried using end-start transaction nodes but it didn’t help :frowning:
Add Share Parameter to RFA-NoExcel.dyn (109.5 KB)
Yes I had the same issue I had zoom into my screen to see the whole thing
I had to use get item at index, as there are levels…
But still the same error… :frowning:
I tried dispose? Perhaps that’s wrong… it didn’t seem to help… :frowning:
Add Share Parameter to RFA-NoExcel-2.dyn (88.0 KB)
Woop Woop! Amazing work :slight_smile:
Thanks Erik, if we don’t speak before, have a great Christmas!
My slightly tweaked version…
Add Share Parameter to RFA-NoExcel (3).dyn (52.2 KB)
Dear Both @erfajo @Mark.Ackerley I want to thank you for solving the issue I will try this when I jump back it and give it a try
I Can now thank you so much after the migration and dealing with the previous issues I am now able to add shared parameters to the families however I can not get the type parameters on there for some reason
Has anyone figured out how to do this now that DanEDU Packages are no longing usable?
I added a node to Crumple the other day that can add parameter sets under Revit > FamilyDoc.
@GavinNicholls I’m not entirely sure on how to use it, I am getting an error on the outcome port of it. Any thoughts?
I have a sample script for the node here:
@GavinNicholls This script is awesome, exactly what I need. My only problem is when I run it, it only makes instance parameters no matter what value I put in the instance column. Any ideas?
FAMILY - TYPES - ADD SHARED PARAMETERS.xlsx (12.2 KB)
Yes I missed out one step accidentally. Add an equals node before the isinstance input and check if they equal “True”. They are still strings, but need to be booleans.
It worked! Thanks for your help, I really appreciate it!
