Hi, I am using Elementsetparameter.byname to assign value to element. the parameter name is not already existing in project, am creating the parameter in this current script but its not working.
Do i need to run seperate script for creating the parameter first prior to this?
Any help?
Yes, I guess you need to make it on two separate scripts. By the way, what it is the yellow warning about?
Look the output of the Parameter.CreateProjectParameter node which is the Parameter, but the input of the Element.SetParameterByName node is the NAME of the parameter.
Regards
yes, if try run second time its working…
Hi Arquimanu, Output of the Create project parameter is currently showing null, and the yellow warning is 'no parameter found by that name. Thanks
Hi @Ganeshkumar,
try use passthrough node from clockwork package between “Parameter.CreateProjectParameter” and “Element.SetParameterByName” nodes.
Cheers
Not required
Element.SetParameterByName expects the Parameter Name as a string (not the created Project Parameter)
projectParameter.dyn (18.4 KB)
Thanks @Vikram_Subbaiah, its works fine, I guess i need to click twice if i use manual Run option, if its in automatic run mode it works perfect.
Thanks @paris, I like the function passthrough, but couldnt get it right, Please have a look,
any thoughts on to include passthrough node, currently not working, any help? thanks
Hi @Ganeshkumar
can you show the error in the node "Element.Set parameterbyname?
Cheers
Hi @paris, the error sayes ‘no parameter found by that name’
Hi @Ganeshkumar
Try use passthrough between string node (element level) and “element set parameter by name” node. Cheers
That works well, Thanks @paris & @Vikram_Subbaiah
can you share the graph?
