Try Element.ParameterExists from Clockwork
How do I pass a null value or prevent creating a new parameter?
You just need to use Boolean result from List.ContainsItem on Names and Parameter Types (everything that is list).
You need to filter Parameter Names with your boolean.
Just mark it as solution. TY
I think it’s more effective to make my print screen appear as solution than the one above. As beginner user, I needed some minutes to figure out how to connect it with Parameter.CreateProjectParameter. Thanks for the solution anyway!
What do you feed into “element” in the Element.ParameterExists node?
Any element that has that parameter.
