Does anyone know how to add a URL in the 3D view in the properties box in Revit, can it be generated from Dynamo or can it be generated directly from Revit?
Welcome to the forum!
Reminder: How to get help on the Dynamo forums - FAQ - Dynamo (dynamobim.com)
It sounds like you’re just asking how/if this is possible, which is more of a Revit question than a Dynamo question. But you can certainly automate it with Dynamo if you need to.
What you’re asking for is just a custom parameter assigned to the View category. You can do that with a project parameter.
Hi! Yes, you can add a URL to the 3D view properties box in Revit. It can be generated using Dynamo or directly within Revit. Consider exploring both options based on your workflow preferences. Good luck!
