Hii, Everyone,
I’m trying to edit the node of “Add Shared Parameters to Project” from Archi Lab Package in order to make it applicable for any Un-opened Revit model ( for Example Linked Models), so what I’ve done is adding a document input to the custom node. the node works fine but the problem is that it creates the parameters in current project not in linked model however i customized the node to work on document not in current project, I just would like to know what is the problem with the below script that leads to that
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
import System
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
_paramName = IN[0]
_groupName = IN[1]
_paramType = IN[2]
_visible = IN[3]
_category = IN[4]
_paramGroup = IN[5]
_instance = IN[6]
inputdocs = UnwrapElement(IN[7]) if isinstance(IN[7],list) else [UnwrapElement(IN[7])]
inputdoc=inputdocs[0]
#Part of script from Clockwork
if inputdoc == None:
elif inputdoc.GetType().ToString() == "Autodesk.Revit.DB.Document":
doc = inputdoc
else: doc = DocumentManager.Instance.CurrentDBDocument
def ParamBindingExists(_doc, _paramName, _paramType):
map = doc.ParameterBindings
iterator = map.ForwardIterator()
iterator.Reset()
while iterator.MoveNext():
if iterator.Key != None and iterator.Key.Name == _paramName and iterator.Key.ParameterType == _paramType:
paramExists = True
break
paramExists = False
return paramExists
def RemoveParamBinding(_doc, _paramName, _paramType):
iterator.Reset()
definition = iterator.Key
break
message = None
if definition != None:
map.Remove(definition)
message = "Success"
return message
def addParam(doc, _paramName, _paramType, _visible, _instance, _groupName, _paramGroup):
message = None
if ParamBindingExists(doc, _paramName, _paramType):
if not RemoveParamBinding(doc, _paramName, _paramType) == "Success":
message = "Param Binding Not Removed Successfully"
message = None
group = app.OpenSharedParameterFile().Groups.get_Item(_groupName)
if group == None:
group = file.Groups.Create(_groupName)
if group.Definitions.Contains(group.Definitions.Item[_paramName]):
_def = group.Definitions.Item[_paramName]
opt = ExternalDefinitionCreationOptions(_paramName, _paramType)
opt.Visible = _visible
_def = group.Definitions.Create(opt)
param = doc.ParameterBindings.Insert(_def, bind, _paramGroup)
return message
#"Start" the transaction
try:
file = app.OpenSharedParameterFile()
except:
message = "No Shared Parameter file found."
pass
builtInCategory = System.Enum.ToObject(BuiltInCategory, _category.Id)
cats = app.Create.NewCategorySet()
cats.Insert(doc.Settings.Categories.get_Item(builtInCategory))
if _instance:
bind = app.Create.NewInstanceBinding(cats)
bind = app.Create.NewTypeBinding(cats)
if isinstance(_paramName, list):
for i, j, k, l, n in zip(_paramName, _paramType, _visible, _instance, _paramGroup):
message = addParam(doc, i, j, k, l, _groupName, n)
message = addParam(doc, _paramName, _paramType, _visible, _instance, _groupName, _paramGroup)
# "End" the transaction
#Assign your output to the OUT variable
if message == None:
OUT = "Success"
OUT = message
Create Shared Paramters in linked models_v1.dyn (23.0 KB)
