Add shared parameter node
@truevis @Mustafa_Mahmoud @Neil_Reilly
Game Over! At first shared parameter need to be created then the script is good to go. I tested this script in Revit 2016 and its working. I have attached files and created a small clip of the process hope you all like it.
Files Shared Parameter.dyn (12.2 KB)
Shared Parameter1.xlsx (8.4 KB)
There was a discussion on this some time ago here: http://dynamobim.org/forums/topic/shared-parameter-creation-from-list/
Basically you can’t use the drop down selectors with this node. Your inputs need to match what Konrad posted in the above thread for it to work correctly. I posted a screenshot in the same thread showing another way of doing this with an excel list of parameters but the formatting is the same otherwise.
That is it , it is work man , thank you for your great work :gift:
رمضان كريم Glad it helped! Can you mark this post as solved.
Sure Boss thank you
I succeeded to make it without excel sheet
I’ve been away for a while. Thank you Kulkul, this is an excellent tool. Also thank Mustafa for keeping this going:-)
It didn’t run straight away after I downloaded, So I made it a bit more understandable for complete dynamo noobs. It can’t hurt to have a few examples here!
The attached excel has a header explaining each rows purpose. The dynamo script has a codeblock that indicates what each excel index id for. I did nothing to the python code apart from changing the input references.
Again, thank you Kulkul for figuring and helping out.
Shared Parameter1.xlsx (9.7 KB)
Shared Parameter Dynamo1 - 2016.dyn (21.8 KB)
Magic good work @Neil_Reilly , that is awesome , thank you for your great participation
thanks allot man!!!
its working grate!!
No Problem:+1: Have fun :wink:
How can I include the GUID of the parameters (e.g. a extra row in the excel file with the GUID)?
First, I want to say great work from all of you. While testing the scripts provided, I discovered these are to be used while in a project. These will not work while in the family editor. Do you guys know of a post regarding families with shared parameters? I have searched far and wide for this with no luck.
@kiknchikn2060 Could you please start a new thread. Thanks :slight_smile:
I have. No response.
