Greetings,
After i read the post below, I wanted to create a similar script. I downloaded the package “Archi-lab.net ” (2 jan. 2018) but i cannot find the nodes you are referring to. Could you explain tell me if i need different packages and how i can see which package i need to have for certain nodes?
Hi all,
After researching the forum and on the web, I can’t seem to find a way to add a newly created filter to a View Template. Is this a limitation of the API?
I was wondering whether is possible a workaround: Create View Template from View (where previously all the graphics setings and filters have been applied).
Also, thanks a lot to @Konrad_K_Sobon for the archi-lab package (especially all the nodes regarding the creation of Filters).
Greetings,
Jesse Heijtink
what node did you mean ?
if you mean overrideGraphicSetting, it’s from Dynamo builtin nodes, under Revit>Filter>OverrideGraphicSetting>ByProperties
Thank you for your reply,
I was looking for the nodes:
ViewFilter.CreateRule
ViewFilter.CreateFilter
Greetings,
Jesse
did found these nodes? i’m looking for them too. I read its under archilab but i cannot find it though i have archi lab installed
