Accessing pressure network
Already updated !!! may i re-install ??
Look at this … package ver. 1.1.21 only works …how strange ?? !!
Also some proper. gives the needed data others don’t. any idea ??!!! Test.dwg (933.8 KB)
everything is working as expected. Have you set your working range to medium?
By the way, you just made the naughty list for not sharing the Civil 3D Toolkit log.
Hi all,
In Civil 3D 2025.1, there are over 70 new nodes for working with pressure networks. Also note that you can use the Object.Geometry node to retrieve the solids for pressure parts.
Awesome new nodes, I am really interested in Pressure Networks. Do you think that the Camber node PressurePipeRun.ByObject will ever come to Dynamo without 3rd party? The only thing I’m still missing in the vanilla Dynamo is the option to create a Pressure Pipe.
