Hi, i have a question if there is a way to make this code repeatable? (this code is making vieuws based on the bounding boxes i put in and by name but i have to change the naming or delete the already made views to be able to run it again what i want is that it make’s the views by bounding box and name and if the view already exist use that view with the new bounding box how is this posible?
Please use some more punctuations next time. Was bit hard to read like this.
Maybe this will get you started. Also you might need to look into the PassThrough node.
Question; What do you use for creating the BoundingBox?
In example; A Family or Scope Box?
