Is it possible to move geometry with python with only using a vector and distance as input?
Wouter
You can always calculate the end point with a function you define beforehand and use this method:
https://www.revitapidocs.com/2020/aaddd413-01b0-2878-3f79-a281abb6d364.htm
I didnt know it also works with vectors. I
ll try to make the array with a nested loop geometry.translate. I`ll let you know if it worked. Thanks again!
