2018.1 VisualMaterials API: Set Render Color
I only have a very basic knowledge of C#, and even less understanding of python, but am trying to convert code from one to the other to work in a Dynamo graph…
Unfortunately, I am struggling to get something that works. Any suggestions here?
C# method, from page 9 of http://thebuildingcoder.typepad.com/files/sd124625_visual_appearance_of_materials_api_boris_shafiro_handout.pdf:
public void SetDiffuseColor(Material material, Color color)
		ElementId appearanceAssetId = material.AppearanceAssetId;
		AppearanceAssetElement assetElem = material.Document.GetElement(appearanceAssetId) as AppearanceAssetElement;
		// A transaction is necessary.
		// Multiple changes to the same asset can be made in one transaction if required.
		using (Transaction t = new Transaction(assetElem.Document, "Change material color"))
			t.Start();
			using (AppearanceAssetEditScope editScope = new AppearanceAssetEditScope(assetElem.Document))
				Asset editableAsset = editScope.Start(assetElem.Id);
				// returns an editable copy of the appearance asset
				// unlike AppearanceAssetElement.GetRenderingAsset(), the edit scope
				// sets up the asset for editing using the classes and utilities from
				// MaterialsManager. If the Asset was not obtained from an edit scope,
				// the setter operations for asset properties will throw.
				// Try to change values
				AssetPropertyDoubleArray4d genericDiffuseProperty = editableAsset["generic_diffuse"] as AssetPropertyDoubleArray4d;
				Color col = color as Color;
				genericDiffuseProperty.SetValueAsColor(col);
				// Commit the entire edit scope.
				// If the appearance asset element is used in one or more materials,
				// they will be updated to match any changes made.
				editScope.Commit(true);
			t.Commit();
Attempted Python code:
def SetDiffuseColor(material, color):
	try:
		appearanceAssetId = ElementId(material.AppearanceAssetId)
		assetElem = AppearanceAssetElement(doc.GetElement(appearanceAssetId))
		# A transaction is necessary.
		# Multiple changes to the same asset can be made in one transaction if required.
		with Transaction(assetElem.Document, "Change material color") as t:
			t.Start()
			with AppearanceAssetEditScope(assetElem.Document) as editScope:
				editableAsset = Asset(editScope.Start(assetElem.Id))
				# returns an editable copy of the appearance asset
				# unlike AppearanceAssetElement.GetRenderingAsset(), the edit scope
				# sets up the asset for editing using the classes and utilities from
				# MaterialsManager. If the Asset was not obtained from an edit scope,
				# the setter operations for asset properties will throw.
				# Try to change values
				genericDiffuseProperty = AssetPropertyDoubleArray4d(editableAsset["generic_diffuse"])
				col = Color(color)
				# Commit the entire edit scope.
				# If the appearance asset element is used in one or more materials,
				# they will be updated to match any changes made.
			t.Commit()
		return material
	except:
		return None
OK, I think I have something that works now:
	try:
		assetElem = doc.GetElement(appearanceAssetId)
		with Visual.AppearanceAssetEditScope(assetElem.Document) as editScope:
			genericDiffuseProperty = editableAsset.FindByName("generic_diffuse")
			genericDiffuseProperty.SetValueAsColor(color)
			editScope.Commit(True)
		return material
	except:
		return None
