Having gained some insight into how to create linear arrays from my previous posting I wonder if anyone can help
to solve with the new study assignment as shown at the attached file.
The task is as follows:
Ribs(lintel) of a certain length must span across 2 walls and to be filled with blocks in between the ribs which must
cover the width between the 2 walls. At approximately the middle should be a gap (between 180-260).
Assuming the above is from left to right in the ‘X’ direction it should also be expanding in the ‘Y’ direction (Range).
Any help in finding a solution of the above task would be highly appreciated (even a small amount of fee is offered)
Thanks in advance
