Hi
After working out the loop, I get zeros for each element that does not meet the conditions described in the function. What do I need to edit in the function to not get zeros in after the loop?
I need a list of correct elements without zeros.
def FilterSystemPipe(_pipe, system_name):
if _pipe.MEPSystem != None:
if _pipe.MEPSystem.Name.startswith(system_name):
return _pipe if _pipe != None or _pipe != 0 or _pipe != "" else 'RandomText'
else: errorlist.append("The pipe hasn't system Id=" + _pipe.Id.ToString())
cold_pipes, errorlist = [],[]
pipes = UnwrapElement(IN[0])
#pipes = FilteredElementCollector(doc).OfClass(Pipe).ToElements())
for pipe in pipes:
cold_pipes.append(FilterSystemPipe(pipe, 'Đ’1'))
OUT = cold_pipes, errorlist
I don’t fully understand your question. But see if this points you in the right direction.
def FilterSystemPipe(_pipes, system_name):
for _pipe in _pipes:
if _pipe != None or _pipe != 0 or _pipe != "":
cold_pipes.append(_pipe)
else: cold_pipes.append("RandomText")
return cold_pipes, errorlist
toList = lambda x : x if hasattr(x, '__iter__') else [x]
pipes = toList(UnwrapElement(IN[0]))
OUT = FilterSystemPipe(pipes,"B1")
@AmolShah
Thank you, I will try to explain in detail.
I need to create lists of pipes that will be sorted by pipe systems. For example, DomesticHotWater, DomesticColdWater and etc.
I’m trying to create a function to filter pipes. My problem is that I get a list of elements that fulfill the condition “The system name starts with …” and elements that do not match this condition in the form of Null.
For example,
List1 [pipe, pipe, pipe]
List2 = [Null, pipe, Null, Null, pipe and etc…]
I need to get List1.
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import specify namespace
from Autodesk.Revit.DB.Plumbing import *
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
collector = FilteredElementCollector(doc).OfClass(Pipe).WhereElementIsNotElementType()
pipesB1 = collector.Where(lambda x : x.MEPSystem.Name.startswith("B1")).ToList()
pipesCH1 = collector.Where(lambda x : x.MEPSystem.Name.startswith("CH1")).ToList()
OUT = pipesB1, pipesCH1
