Ive encountered a small issue in ironpython. When I use the underneath code it filters out the Nonetypes. This should also work with filter(). But when I use the filter() function to do this is also filters the zero
s from the list…
I expect it to only filter out the None`s…
Did anyone have the same issue or am missing something?
T=0
for it in itm:
if it is None: break
T+=1
#itm4 = filter(None,itm)
Exceldata_Y_1.append(itm[0:T])
hi @wouter.hilhorst
replace your python code above with this:
Exceldata_Y_1 = list()
for it in itm:
if it != None:
Exceldata_Y_1.append(it)
Hi, That also works and is already a bit shorter, thanks!
But the solution with the T counter in my original code also works.
The problem is that the filter() should also work but doesnt. It filters out the nonetypes AND the zero
s which it shouldn`t in my opinion?
Wouter Hilhorst
you are using filter incorrectly, the syntax is
filter(function, iterable)
please use the following:
itm4 = filter(lambda x: x != None, itm)
Please mark my answer as the solution if it solves your question. Thanks.
