Is there a node that returns the value true if an xref is loaded? The node “Xref.IsOverlay” exist but not the node “Xref.IsLoaded”.
Raf.
Here’s how to do it with Camber nodes using Block.IsUnloaded
Block.IsUnloaded
Thank you Mike! That solved the problem.
