Hello I am trying to write information from an Excel-file to specifick elements. I have tried to use both GUID and BatID as identifier. I think the problem is in the ElementById-node or in the Element:SetParameterByName. The unconected nodes laying around are ones I have tried without sucsess. Anybody who can see a solution?
This script is a critical part of my exam which has to be finished before monday afternoon, any help will be much appreciated!
This is a link to a Dropboxfoleder where you can find a test model, the script, and the Excel-files needed:
Shared with Dropbox
Leif
This is the error Im getting:
Have you updated the Archi-lab package? The Id to element-node seems to be working on my end:
And also, the link provided is for another folder completely I guess. (Altså Cv’n din+ prosjektoppgave. )
Hei Leif!
It’s most likely the id to element that’s your problem, if Josteins suggestion doesn’t work you can try this:
clr.AddReference('RevitAPI')
items = IN[0]
elementlist = list()
for item in items:
elid = ElementId(item)
elementlist.append(doc.GetElement(elid).ToDSType(True))
OUT = elementlist
Thanx, i have changed the content in the folder. Will try your solution in a minute
I have tried Josteisn fix, updated the package. At least I get somthing out of the node:
Einars solution:
I dont know what I have done wrong, I copy/pasted the code and added "at the start and end of the code
Thanx for trying. I will get back to the problem tomorrow, maybe a good nights sleep will help
You need to add a ; (semicolon) after the last " in the code block. Also make sure your ids are integers.
The String.ToNumber node solved the problem. Thanx a lot!
Leif
