Writing to text file using python node
I am trying to export some formatted message from python node to a text file.
But I am not getting the output because of some error. I have pasted the screenshot of the code and the error in node.
Please help.!
Screenshot%20(6)|690x388
While simply writing to a file e.g. ‘text.txt’ is valid for a normal python script, you need to provide the full path for writing in dynamo.
import sys
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
import os
filedir = r'C:\test'
filename = 'text.txt'
filepath = os.path.join(filedir, filename)
message = 'example message’
with open(filepath, 'w') as f:
    f.write(message)
Hi All
I am trying to append text to a .txt file using python, but I can’t seem to get it to work.
This is something I have done several times before outside the Dynamo environment.
I even imported the entire boilerplate to see if I was missing anything, but that did not help.
What could I be missing?
See the code with the full boilerplate below.
Thanks for your help.
# Import Libraries.
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
app = uiapp.Application
import os
import logging
from datetime import datetime
# Inputs.
script_name = IN[0]
file_path = IN[1]
# Set the working directory.
try:
    os.chdir(r'your path')
except:
    print("Server working directory not set.")
# Configure error logging file.
logging.basicConfig(filename='script_usage_log.log',\
    level = logging.ERROR)
# Get current user.
try:
    current_user = os.environ.get('USERNAME').title()
except Exception as e:
    logging.error(f'Current user login NOT gotten. {os.getlogin().title()} PC.'
        f' {datetime.now()}. Exception: {e}.')
    sys.exit()
# Get the document path.
try:
    document_name = doc.PathName
    logging.error(f'Document Path NOT gotten. {os.getlogin().title()} PC.'
    sys.exit()
# Check if the document is workshared.
try:
    document_isworkshared = doc.IsWorkshared
    if document_isworkshared == True:
        workshare_status = "Workshared"
        workshare_status = "Not Workshared"
    logging.error(f'Document workshare status NOT gotten. {os.getlogin()} PC.'
    sys.exit()
# Get the current date and time.
try:
    time_now = datetime.now()
    logging.error(f'Current time NOT gotten. {os.getlogin()} PC.'
    sys.exit()
# Write information to file.
file = open(file_path, 'a')
write_content = ("User=" + current_user + " | Script Name= " + script_name +
    " | Workshare Status= " + workshare_status + " | File Path= " +
    file_path + " | Time= " + str(time_now))
file.write(write_content)
I figured it out, thanks.
I needed a file.close() after the file.write()
Thank you.
