This post is actually two questions related to the same class.
I have been trying to develop a mini Dynamo Sandbox to get the workspace from a filepath through the code below.
If Dynamo is closed, in order to read workspace information, I need to first make an empty JournalFiles call to dynamoRevit.ExecuteCommand(dynamoRevitCommandData) or the code below does not read information.
After calling the previous, despite reading workspace information, it does not run the script via;
HomeWorkspaceModel homeWorkspace = workspacint as HomeWorkspaceModel;
homeWorkspace.Run();using System;
using System.Collections.Generic;
using System.IO;
using TaskDialog = Autodesk.Revit.UI.TaskDialog;
using Newtonsoft.Json;
using Dynamo.Core;
using Dynamo.Graph.Workspaces;
using Dynamo.Models;
using Dynamo.Scheduler;
using Dynamo.Engine;
using Dynamo.Graph.Nodes.NodeLoaders;
using Dynamo.Graph.Nodes;
using Dynamo.Utilities;
using System.Linq;
using System.Reflection;
using String = System.String;namespace NodeLibrary
public class NodesInfo
public static bool IsTestMode { get; set; }
public static LibraryServices libraryServices { get; set; }public static EngineController engineController { get; set; } public static DynamoScheduler scheduler { get; private set; } public static NodeFactory nodeFactory { get; set; } public static CustomNodeManager customNodeManager { get; set; } public class DynamoPreferencesData { public double ScaleFactor { get; internal set; } public bool HasRunWithoutCrash { get; internal set; } public bool IsVisibleInDynamoLibrary { get; internal set; } public string Version { get; internal set; } public string RunType { get; internal set; } public string RunPeriod { get; internal set; } public DynamoPreferencesData( double scaleFactor, bool hasRunWithoutCrash, bool isVisibleInDynamoLibrary, string version, string runType, string runPeriod) { ScaleFactor = scaleFactor; HasRunWithoutCrash = hasRunWithoutCrash; IsVisibleInDynamoLibrary = isVisibleInDynamoLibrary; Version = version; RunType = runType; RunPeriod = runPeriod; } public static DynamoPreferencesData Default() { return new DynamoPreferencesData( 1.0, true, true, AssemblyHelper.GetDynamoVersion().ToString(), "Automatic", RunSettings.DefaultRunPeriod.ToString()); } } public static bool isValidJson(string path, out string fileContents, out Exception ex) { fileContents = ""; try { fileContents = File.ReadAllText(path); fileContents = fileContents.Trim(); if ((fileContents.StartsWith("{") && fileContents.EndsWith("}")) || //For object (fileContents.StartsWith("[") && fileContents.EndsWith("]"))) //For array { var obj = Newtonsoft.Json.Linq.JToken.Parse(fileContents); ex = null; return true; } ex = new JsonReaderException(); return false; } catch (Exception e) //some other exception { Console.WriteLine(e.ToString()); ex = e; return false; } } public static bool OpenJsonFile( string filePath, string fileContents, DynamoPreferencesData dynamoPreferences, bool forceManualExecutionMode, out WorkspaceModel workspace) { workspace = WorkspaceModel.FromJson( fileContents, libraryServices, engineController, scheduler, nodeFactory, IsTestMode, false, customNodeManager); workspace.FileName = filePath; HomeWorkspaceModel homeWorkspace = workspace as HomeWorkspaceModel; if (homeWorkspace != null) { homeWorkspace.HasRunWithoutCrash = dynamoPreferences.HasRunWithoutCrash; RunType runType; if (!homeWorkspace.HasRunWithoutCrash || !Enum.TryParse(dynamoPreferences.RunType, false, out runType) || forceManualExecutionMode) runType = RunType.Manual; int runPeriod; if (!Int32.TryParse(dynamoPreferences.RunPeriod, out runPeriod)) runPeriod = RunSettings.DefaultRunPeriod; homeWorkspace.RunSettings = new RunSettings(runType, runPeriod); } CustomNodeWorkspaceModel customNodeWorkspace = workspace as CustomNodeWorkspaceModel; if (customNodeWorkspace != null) customNodeWorkspace.IsVisibleInDynamoLibrary = dynamoPreferences.IsVisibleInDynamoLibrary; return true; } public static string validjson; public static void RequestRun(string filepath) { Exception ex; NodesInfo.isValidJson(filepath, out validjson, out ex); NodesInfo.DynamoPreferencesData nuevo = NodesInfo.DynamoPreferencesData.Default(); NodesInfo.OpenJsonFile(filepath, validjson, nuevo, true, out WorkspaceModel workspacint); HomeWorkspaceModel homeWorkspace = workspacint as HomeWorkspaceModel; homeWorkspace.Run();}
