hi everyone - I would like to use Bang! in my script for batch maintaining revit files in the background.
To do so I would need an input for the opened documents.
Would it be possible to implement it?
I went ahead and made this a new topic
I won’t be able to get you a perfect solution, but, Bang will not support this. You are going to need to use a custom Python node to achieve this. I would also say to provide more information regarding how you are opening the documents in batch.
This python script would iterate along an input list of Autodesk.Revit.DB.Documents
clr.AddReference('RevitAPI')
clr.AddReference('System')
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
app = DocumentManager.Instance.CurrentUIApplication.Application
documents = tolist(UnwrapElement(IN[0]))
allWarnings = []
for d in documents:
warningsForThisDocument = []
warningsForThisDocument.append(d.GetWarnings())
allWarnings.append(warningsForThisDocument)
OUT = allWarnings
