Work with levels in python script input
I bring python code to sort the point accord the distance:
from Autodesk.DesignScript.Geometry import Geometry
pts = IN[0]
margin = IN[1]
dist1 = Geometry.DistanceTo
Groups, Queue = [ ], [ ]
while pts:
	group = [ ]
	Queue.append(pts.pop() )
	while Queue:
		p1 = Queue.pop()
		group.append(p1)
		for i in xrange(len(pts)-1,-1,-1):
			if dist1(p1, pts[i]) <= margin:
				Queue.append(pts.pop(i) )
	Groups.append(group)
OUT = [sublist[::-1] for sublist in Groups[::-1]]
the problem is when the input have more than one list level the code will not give right result as the pic :
how i can work with level lists in python
thanks
Hi @Mkq_1993 maybe try
  • add for looping into your python node
  • or use ProcessList def function
  • or create a custom node
  • or flatten list, process list and another python to retrieve the correct level.
    Cheers
I can’t deal with python yet, also if i can’t make flatten for list because that will ruin the last sorting
Hi @Mkq_1993 ,
Like paris said, you could put this python script inside a custom node, then list levels and such should work as intended :slight_smile:
Hi @Mkq_1993 can you share a simple RVT file with your dyn?
Cheers
Cable Tray Support3s.dyn (709.3 KB)
i want to move the script after vector direction sorting
https://easyupload.io/yru782
Just to add to the topic, if you are willing to put your Python block into a custom node this will enable levels to be used on its inputs. If you list the input to the node in the format…
this will instruct the node to treat the input exactly as is, but enable you to also instruct it to work @L1, L2 etc.
