Can somebody help me, what is the problem why it is Null in code block, I’m trying to subtract the List of coordinates from excel file.
Hello @dexterdeluna122685 and welcome to the community…do you mean something here…
Not really sure what you mean….you wanna count them or ??? Try give an exemple
count them
List.Count will tell you how many there are.
can you give me a solution to this. another node to give me the list which is already an answer
Do you want to subtract value 1 from value 2?
yes, but must be in listed like 1 to13
Remove the previous code block entirely.
Expand the preview of the data in the ‘easting’ group so we can understand what you are working with. Also wire an Object.Type node in after it so we can confirm all the data is a number of some sort.
Not sure,are you sure these are numbers, try tjeck it with the node objecttype…another thing is you have null in your list and looks like you have whitespaces…so i assume its a string and need to be converted to double…if you want then share your dataset and we can see whats goin on…
I want to subtract list first item to list last item. is there anything nodes I can use to give me the answer on list
I wonder if you could help me fixing my problem in dynamo script, maybe I can send you the Dynamo file .dyn via email and fix it. sorry for bothering you. it’s just that I wanted to have a finish output on this script. thank you in advance
no worries…if you upload you dataset here…rvt, dyn file…you can upload here a link to webtransfer, filetransfer etc…and i will try to help you…
