Some short issue:
x.Parameters[0] == "Ebene";
Why does it not work?
is there a slidly error in my syntex?
KR
Andreas
Some short issue:
KR
Andreas
you’re trying to compare an object of type Parameter to a string, which is not going to work. Try getting the parameter’s name or value first. For example:
x.Parameters[0].Name == "Ebene"
so that means:
“look for ParameterName “Ebene”(Level) and filter the elements on it”
is this correct?
What i want to do is list the elements by Value “Level” (UG,EG,OG01,…)
