Is there a way / package / node to show who created an element? All my searches have come up empty on this.
Thanks in advance!
Thanks in advance!
There is a way
http://www.revitapidocs.com/2018.1/1e54c25f-7d7a-7484-be7b-d741084418a9.htm
I don’t know any packages that have that functionality though.
Thanks. I was hoping to find something for a non-workshare enabled model. This may work, though, provided the process of enabling worksharing doesn’t “reset” all of the element owner info.
Thanks again!
Yes it works, also for not-workshared models. I’m currently working on a Revit Addin and I already have a button to get those information, but not a dynamo custom node.
However it should be very easy to create one with Python. If you have no clue where to start, I can make it for you, but it would be not before this evening.
That would be awesome! I literally just started watching a LinkedIn Learning session 10 minutes ago about the basics of Python so that would be a great little program to mess around with and learn about both Python and the Revit API. I totally appreciate that.
I can’t remember exactly, but I think the Archi-Lab package has a node for this, but I am not at a computer.
I was finding it a bit weird, that nobody had the idea to make a node out of it.
Here are two nodes from Archilab and Rhythm:
I tested it on a not workshared file (just creating a simple file,close it, let a colleague add a door, save it and close it again) and it works
Python code for same:
clr.AddReference('RevitAPI')
# For accessing Document and Transactions
# Creating Instance of Document and Application
ele = UnwrapElement(IN[0])
info = WorksharingUtils.GetWorksharingTooltipInfo(doc,ele.Id)
OUT = [info.Creator,info.Owner,info.LastChangedBy]
you may get this function from pyrevit as well "who did that?? "
That it will. So would cutting a new central (open detached and saving as a new model). This is why I recommend frequent backups and starting worksharing on day 0 of the project.
