While loop for finding the appropriate surface area
Depending on the accuracy needs, you could make a python loop with a desired number of iterations (accuracy) that re-calcs the area from the offset. I prefer not to use a while loop. If you use it, cap it so that any mistakes (like briefly clicking away before finishing) will not freeze Dynamo.
Below is a sample, that can be really improved for speed:
  • can add a way to offset in either direction
  • can be optimized for speed (super rough logic…)
These settings are not too slow for this single surface example…
2022-03-22 - 20-01-46
Python Node Code
# EvolveLAB | https://www.evolvelab.io
# 2022-03-22
# inputs
polyCurveOrig = IN[0][0]
targetArea = IN[1]
offsetStepDist = IN[2]
def areaOfPolyCurve(pCurve):
    area = Surface.ByPatch(pCurve).Area
    return area
# vars
polyCurveNew = polyCurveOrig
offsetDist = 0
newArea = areaOfPolyCurve(polyCurveOrig)
# assumes that original shape is larger than the target
for step in range(100): # 100 max tries
	if newArea < targetArea:
		offsetDist = offsetDist - offsetStepDist # undo last offset
		offsetStepDist = offsetStepDist / 2 # gradually increase the resoution if went over
	offsetDist = offsetDist + offsetStepDist
	polyCurveNew = Curve.Offset(polyCurveOrig, offsetDist)
	newArea = areaOfPolyCurve(polyCurveNew)
OUT = [offsetDist, newArea, polyCurveNew, step]
