Where to get the LibraryServices for creation of CodeBlockNodeModel in view extention
Does anyone have a suggestion how to get the ‘Dynamo.Engine.LibraryServices’ that is needed to create a ‘Dynamo.Graph.Nodes.CodeBlockNodeModel’ from within a view extention?
so far as i can tell is a singleton in the Dynamo.Engine but im not sure how to get that one either from a view extention
ViewLoadedParams vlp = ExtentionDefaults.ViewLoadedParameters;
//Need a library service to create a codeblocknodemodel, where do i get it from?
Dynamo.Engine.LibraryServices libraryServices = new Dynamo.Engine.LibraryServices(new Core(new Options()), vlp.StartupParams.PathManager, vlp.StartupParams.Preferences);
Dynamo.Graph.Nodes.CodeBlockNodeModel inputNode = new CodeBlockNodeModel(libraryServices);
inputNode.Name = “INPUT”;
inputNode.GUID = Guid.NewGuid();
//Set position to left top of group
double _x = this.AnnotationModel.X;
double _y = this.AnnotationModel.Y + this.AnnotationModel.Height;
ExtentionDefaults.ViewLoadedParameters.CommandExecutive.ExecuteCommand(new DynamoModel.CreateNodeCommand(inputNode, _x,_y,false,false), ExtentionDefaults.UniqueId, ExtentionDefaults.Name);
Have you checked out the CodeBlockNodeTests on the Dynamo core tests Github? From memory I’m sure you can get to the LibraryServices instance from the current DynamoViewModel instance.
I have tested in a quick ViewExtension and works fine for me. Here is some code you can use…
A static NodeUtils Class…
using Dynamo.ViewModels;
using Dynamo.Models;
using Dynamo.Graph.Nodes;
namespace CodeBlockTest
    public static class NodeUtils
        public static void CreateCodeBlock(DynamoViewModel _dvm, double xPos, double yPos, string code)
            var cbm = new CodeBlockNodeModel(_dvm.Model.LibraryServices);
            var cmd = new DynamoModel.CreateNodeCommand(cbm, xPos, yPos, true, false);
            cbm.SetCodeContent(code, _dvm.Model.CurrentWorkspace.ElementResolver);
            _dvm.ExecuteCommand(cmd);
ViewExtension Class inheriting iViewExtension…
using System;
using System.Windows.Controls;
using Dynamo.Wpf.Extensions;
    public class CodeBlockTest : IViewExtension
          public string UniqueId
            get
                return Guid.NewGuid().ToString();
        // Edit string when starting a new ViewExtension...
        public string Name
            get
                return "CodeBlockTest";
        public void Startup(ViewStartupParams p)
        public void Loaded(ViewLoadedParams p)
            // Get current DataContext as DynamoViewModel...
            var _dvm = (DynamoViewModel)p.DynamoWindow.DataContext;
            // Create Menu Items...
            Menu MainMenu = p.dynamoMenu;
            MenuItem _myMenu = new MenuItem
                Header = "Code Block Test"
            MainMenu.Items.Add(_myMenu);
            MenuItem _viewExtensionMenuItem = new MenuItem
                Header = "Create Code Block"
            _myMenu.Items.Add(_viewExtensionMenuItem);
            // Add click event to MenuItem...
            _viewExtensionMenuItem.Click += (sender, args) =>
                 NodeUtils.CreateCodeBlock(_dvm, 0, 0, "HelloCB");
        public void Dispose()
        public void Shutdown()
EDIT: Make sure you have the following Dynamo .dlls referenced in VS…
  • DynamoCore.dll
  • DynamoCoreWpf.dll
  • ProtoCore.dll
Hope this helps.
Cheers,
Dan
Many thanks this seems to work perfect for me!
